By tom greeni
#331635
hi people
right ok, this is my first post !
i love the clock the radio 1 studios and i have found a couple of sites that will only sell them to large companies !
does any one no where i could get one on the retail market, THANKS !
By tom greeni
#331748
you cant order them from that site because you must own you own large company
and you cant buy them in singles you must order them 10 or 20 of them !
does any one no where i can just buy one of them
By tom greeni
#331753
hi again !
this has got nothing to do with the clock !
but i dont understand the chat section of this web site !
no some is every in the lobby and i dont no any private lobbies ( can i have some idea of what is with this section )
and does any one have chris moyles' xbox live address
thanks !
Pardon?
Hahahaha.. good one.
Oh, you were serious?
By tom greeni
#331757
right thanks charlalottle !
nice one ( and i dont do sentences - cos im a rebel ! )
thanks to you all !
This will also mean you wont last long around here.
Did you try the things I suggested when I replied to your PM? Plus - are you able to afford these clocks? They are hundreds of pounds! One I saw on eBay was at £250 and that was a second hand one.
Personally, i'd just check on teletext.
By TIAL
#331760
No one is ever in the lobby/chatroom because it's the weekend and people are out doing things :D
You might want to rethink about 'not doing sentences' - it can make it hard for others to read which can make it frustrating. Really, the policy here is to write as best as you can. :)
By tom greeni
#331770
ok, people it seems im starting to understand this place.
thanks for all your advice over the last couple of days. i think i might stick around for a bit longer.
thanks again 8O
By TIAL
#331773
Excellent :D
No need to be shocked, we just like people who make an effort because it's easier for all of us! 8)
I personally don't mind typos/grammar errors, as long as they aren't done on purpose - I think that it's easy to slip into the habit of concentrating on people's typing mistakes, rather than what they are trying to say.
This isn't aimed directly at you Tom, it's just my stance on the matter :D
By tom greeni
#331777
Done !
from no on my spelling and grammar will be Tip Top for you all. right im going off for a bit but i will be back later for a good old chat.
thanks people, hope to make my self at home here soon !
thanks to you all :o
Tom Greeni
Done !
Tom Greeni
Not off to a good start in the tip top stakes! 8O
Sorry I'm a bit of a pedant but nowhere near as bad as Topher, mind you as long as you don't "lol" you will probably be ok.
Really don't want photographic evidence of that so..................NO
By SpaceBoy
#332079
The clock by Wharton is mainly for commercial and military applications which I am assuming most folks are referring to but I have come across a very similar clock to the Radio 1 circle-line clock.
The closest clock which would be in most folks price range would be a clock from jaycar electronics if you do a search on Gregg Oogle you will find the site and it is item CAT. NO. AR1788 - Blue LED Analogue / Digital Clock for £28 and before anyone else mentions the obvious, yes the clock is blue and not red like the Radio 1 circle-line clock but there is a kit pack available and so if you are a bit tech savvy and able to do circuit board work you could get the kit and replace the blue LED's with the red ones. If you do not want to go to the expense of replacing the LED's and buying the kit there is (again if you are tech savvy which i am not) a few sites which have the microprocessor code and programming needed to make from scratch your own circuit board and chip-set to control the clock if you did not want to dismantle and put back together the one from jaycar. This would, I am sure be a project someone could complete quite easily if the know how is there or they have access to the right equipment.
Be mesmerised by this amazing clock!
It is a slightly different, completed version of our "Clockwatchers" LED Clock Kit (KC-5416), so you get all the benefits without having to put it together. The mechanism drives a 7 segment, 12 or 24 hour digital time display. The segments are 48mm high and consist of 3mm high brightness LEDs. The 200mm diameter path contains 60 x 5mm high brightness LED's on a 60 second circuit. One LED lights up every second. When the entire face has been filled one minute has elapsed and the digital clock increments by one and the process starts again.
The housing unit consists of a diffused glass face in black metal casing and measures 250 (L) x 250 (H) x 50 (W) mm.
> 9V adaptor included
> Back-up battery (for memory only ) included
Alternatively, if you just liked the way it tells the time then knock yourself out and get the blue one. Hope this helps!
:D
By tom greeni
#332102
you are actually amazing Spaceboy, First the Mac stuff and now this ! i have got one on order now, and i no i guy that can change the circuit board to change the LEDS good lad. keep the good information coming !
Thanks :D
By SpaceBoy
#332111
Careful though! Remember Black to Black, Green to Green and Blue to bits! :D (A wiring joke there)
By tom greeni
#332123
( thats the line finishing are Mac conversation because we got told off by the big boss Chris ) :( sorry !
By tom greeni
#332125
This is just one big slap in the face for me ! I love this forum but today all i get is abuse, Any chance of a break Chris
By TIAL
#332136
I'd hardly call Tom's spelling 'horrific', maybe it's not perfect but I (personally) don't ever feel the need to pick someone up on it!
(And yes I do realise I am fighting a losing battle as it's Chris I disagree with :D)
(that's the line separating your post with horrific spelling from mine which is correct)
Try clicking and learning about this pronoun, and this verb.
Chris, I think I love you.
