By Bridgie
#23094
i know a lot of people record the show onto mini disk but i was wondering if it was possible to record straight onto the computer and how to do it. its so anoying missing the show if im working. any info please.
By Funky Drummer
#23137
Well....
IF I decide to record any bits of the show, it may be done a number of ways.
If I record at home, then through my stereo onto MD then into my computer.
If I'm at work, same method in the studio through the mixing desk, but I can also go through the desk straight onto the computer, save as MP3, jpb's done.
Simple.
Rich~
By David
#23139
Well....
Should you not be doing something productive in that studio rather than listening to Moyles?
David
By Funky Drummer
#23143
yeah, and I usualy am, but I have the tuner on so that I can listen to moyles at the same time and use the cleen feed off the desk through to the computer with tuner on pre-fade. :wink:
By The Peter Kay Fan
#23151
or you can use a USB wave finder and record dtaright to your hard drive
By Matt
#23152
I set my PC at work to record a 10 minute loop of the show, then if there is something worth saving I do.
This way you don't end up with 3 hours of audio to edit :D
#23154
but what happenes if the bit that wants saving starts after 5 mins of the loop and finishes at five minutes into the next loop?
does that matter?
By Matt
#23156
You've always got 10 minutes worth.
By Bridgie
#23157
thanx for the help. i would be grateful if u could pm me or something to explain how to do the loop thing in a bit more detail. sounds good
#23159
but surely when the ten minutes is up, a new loop overwrites the first loop, meaning you lose the first five minutes of the thing you want to save?
or am i talking out my /-\rse?
just trying to find out a little more info
By Matt
#23160
Basically, you set the software to record the last x many minutes. Then if something good happens in the last x minutes you can save it.
By edmondo
#23167
I have a Psion Wavefinder (costs £40) which lets me recieve digital (DAB) streams through my PC. This lets you record the audio stream straight to mp2/mp3, so the quality is pretty good :-).
By jc
#23217
...I have the tuner on so that I can listen to moyles at the same time and use the cleen feed off the desk through to the computer with tuner on pre-fade. :wink:
So the person who told me that it's practically illegal to have a radio tuner in a radio studio because you're not allowed to re-transmit another station was talking nonsense? - jc
By Funky Drummer
#23219
No, because it's not re-transmitting. FOr example, if I'm editing, dubbing, recording, WHATEVER in the studio, I put the tuner on PREFADE (i.e. so it doesn't go out) and use the cleen feed function on the desk so that the tuner is recorded on the pc. *ARGH!!!*
By jc
#23226
Yes, I read the pre-fade bit. It's a neat solution, but I don't see why you should be allowed to re-transmit in the first place (if you wanted to). - jc
By Matt
#23230
It's not illegal if both stations have agreed otherwise.
Take the BBC local stations, at night most of them switch to BBC 5 Live. At about 2.15am Five Live broadcast the news from ABC in America.
So that's being broadcast over hundreds of different stations at the same time.
By Funky Drummer
#23270
The reason you can't re-transmit on ILR stations is that it would intefere with license agreements and also copyright regulations. For example, if you had two local radio stations with transmission areas as follows:
| X | | Y |
Basically, their transmission areas overlap. If station X was to put on station Y's output, then it would be transmitted over a greater area than station Y's license allows, therefore breaching radio authority regulations.
Understand? (sorry, my diagram was a bit crappy!!) :?
Rich~
By jc
#23285
Sure. If only that applied to the God-awful Scottish Night Network. :? - jc
By stevotrash
#23288
Heres what you need luv, a cable with a mini jack on both ends.
1. Plug one end into the stereo headpjone socket
2. Plug the other end into the back of your computer, next to the 'speakers' port
3. Get some audio software to 'record from line in'
Why the * has a certain group of people turned this thread into 'amateur radio audio musings'. I'm suprised how some of you manage to distinguish the processes of this equitpment when you double bent over it with your pants around your ankles.
By Funky Drummer
#23329
Why the f[h]uk has a certain group of people turned this thread into 'amateur radio audio musings'. I'm suprised how some of you manage to distinguish the processes of this equitpment when you double bent over it with your pants around your ankles.
Calm down stevo, I was only saying how I (sometimes) recorded bits of the show. Someone asked a question relating to that; I answered.
By jc
#23359
Yup. And besides, it's professional radio. ;) - jc
