Where's the 'Don't give a sh¡t' option?
It's an upside down ! if you look closely the gap between the line and dot is smaller on the exclamation mark than on the i
Traitor? traitor to whom? i was never on your sideIt's an upside down ! if you look closely the gap between the line and dot is smaller on the exclamation mark than on the i
You only know that because your brother told you I'll bet. Keep your mouth shut next time traitor.
As for how you type an upside down ! I'll leave you guessing. Have some candles ¡i¡i¡i¡i¡
